Direct bolt on LS1 spindles, brakes, w/ 17x9.5 ZR1's
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
OK, I'm tired of searching and finding no real answers. I'm looking at a set of spindles, calipers and rotors from a 99 SS car. I'm currently running the stock 88 spindles w/ S&D rotors and spacers on the front. I have read somewhere that I can do a direct bolt on of the spindles and I can remove the spacers from the equation. ** Correct me if I am wrong please.
Can I do this with the stock A-arms?
If not, can I use the 4th gen A-arms instead?
Details on the mods for the steering would be helpful.
Nick
Nick
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Direct bolt on LS1 spindles, brakes, w/ 17x9.5 ZR1's
I don't see how this could work because 3rd gen is modified Macpherson strut and 4th gen is SLA suspension.
Would also like an answer to finding a bolt on spindle so I can get some proper brakes on this thing however.
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
You must modify the factory 3rd gen spindle to accept 4th Gen LS1 brakes or C5 brakes. I got my kit from bigbrakeupgrade.com, but have heard good things about kore3 as well. They make some nice aluminum hubs.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
No spindle options othef than stock, no other spindle will work with redesigning the entire front suspension.
Car: 87' IROC
Yup they will certainly not bolt on. There are many great brake options on the OEM spindle though.
