LS1 Rear Question
Old Mar 28, 2013 | 09:52 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
LS1 Rear Question
Hey all, will finally be doing my drum-LS1 rear upgrade on my 91RS this weekend. My only probelm is that before I start, I need to make sure that I have everything, otherwise I wont be able to go get what I need (no other vehicle and running on borrowed time/place)... So let me run through what I have and if someone sees something I am missing, please let me know.
-LS1 backing plates with 4 mounting bolts
-LS1 parking brake cables with brackets
-parking brake shoes
-hardware for the parking brake that attaches to the backing plate
-rotors
-LS1 calipers with mounting hardware and clips
-Brake pads
-gallon of gear oil (no additive/synthetic because open rear)
Will I need to replace the bearings after I pull the axles? If so, which ones are the ones to get?
Old Mar 28, 2013 | 10:58 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: LS1 Rear Question
You will need this:
Old Apr 8, 2013 | 08:50 AM
TheRock86's Avatar
what plate is that for? ebrake bracket from 4th gen?
Old Apr 8, 2013 | 10:04 AM
Car: 1991 Camaro RS
Engine: L98 350 TPI
Yea, that is for the parking brake at the front, it welds to the underside of the car to hold the front of the cable
Old Apr 8, 2013 | 12:04 PM
TheRock86's Avatar
you have take the stock one off right and weld in its place the 4th gen one? and do i need to customize the 4th park cable or can i just run from the rear shoes to the handle? also do i have to use a the gen handle or can i stay with stock handle? tried searching around tgo but can find anything
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
