want a better master cylinder
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
Currently have stock 4 wheel disc all around. It's always had poor braking performance even after replacing lines and calipers, pedal is hard. Booster is holding vacuum. I have an adjustable prop valve I was going to install when I replace the master. I plan on going to bigger brakes in the future and want a master cylinder that will supply enough volume. What are my options?
