Brakes on a budget?
Old Mar 31, 2013 | 11:00 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Brakes on a budget?
I don't want to skimp on something important like brakes, trying to figure out the best way to proceed.
My car (1985 Camaro) currently has disc all the way around; I've looked at a lot of the upgrade kits, not sure if that is the best way to go or just replace the pads & rotors with a stock version.
The C4 upgrade can be found for around $900, this is just for the front. Would some kind of upgrade be required for the rear as well? Or can I just do an upgrade on the front & then replace the pads and rotors on the rear?
I would love to keep the total price under $1,000 but am willing to go higher if it's a better decision in the long run. Thanks.
Old Mar 31, 2013 | 01:32 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Re: Brakes on a budget?
My suggestion if you want cheap is to tune the stock system and make sure you are getting the most out of it. Disks, pads, proportioning, etc.
Old Mar 31, 2013 | 03:06 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Is there a preferred brand of performance stock replacements? I know that Tire Rack sells some slotted rotors (Hawk, StopTech, etc.) that I can get for $70 - $100 each. I can also get the Napa brand Premium drilled and/or slotted rotors for cost through my brother. Just wondering if any of these are better or worse than others?
Old Apr 4, 2013 | 01:20 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
My pads and rotors on the front are ebay drilled and slotted with ceramic pads... the pads were a bit dusty for ceramics, but very reliable and predictable. When the pads wore out, replaced them with autozone ceramics.
rear is drum, so that is another completely different issue i have, but i got the parts for an LS1 rear swap, GM backing plates and calipers, and ebay drilled and slotted rotors wtih ceramic pads
Old Apr 4, 2013 | 01:28 PM
87350IROC's Avatar
Car: 87' IROC
No question, use the Napa Premiums.
Jorlain
Oct 8, 2015 01:57 AM
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
