1990 gta hardbrake
Car: 89 firebirdl90 gta
1990 gta hardbrake
have hard brake pedal car stopps safely but with firm presssure applied, worst when emerency stop simulated. gets scary., slow to grab. need possible solutions ,,over last 4 years have tried new master cylinders a proportioning valve , new hose braided, tested vac on intake, flushedfluid several times, different pads, new rotors, a remanufacter booster. new ssbc front calipers .also did spring change , using heavest spring noted which does help rear calipers slow rear wheels now. front rotors will heat up during testing . but pedal still hard. booster change had no effect .infact all things i have tried did nt improve hard pedal . have redone entire car but this is got me. any suggestions to try.. i also have a 1989 form.bird and its braking totaly better? dandav65 thanks
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
