Drum Rear to Disc
Old Apr 5, 2013 | 12:26 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Drum Rear to Disc
Hey guys,
I have a 91' Camaro with drums on the rear. Want to upgrade to discs. Through the research I have found it looks like there are 3 options. 1. Buy a disc conversion kit. The one I like is here,
http://www.summitracing.com/parts/rs...t/model/camaro
2. Buy a 4th gen rear and bolt it up. 3. Find a 3rd gen rear end with disc.
I have a few questions,
In regards to 1. How hard will it be to find replacement rotors and pads for this kit? Will i be able to go to the local auto parts store and buy them (rotors/pads)? 2. Any pictures of this mod to show how far out my tires will stick out? I know its about 2" but id like to see it before I decide to go this route. I like this option as I should be able to find a Z28 so i can get the benifits of a posi and easy-ability of finding rotors/pads/calipers.
Thanks for your time
Bill
Old Apr 5, 2013 | 01:25 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Re: Drum Rear to Disc
doing this setup (hopefully) this weekend.
https://www.thirdgen.org/ls1reardisc
uses parts readily available at autoparts stores (98-02 camaro stock pads/rotors/calipers/rubber lines)
Also, doesn't change the wheel spacing like a full rear swap
Old Apr 6, 2013 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Other issues in the conversion are addressed below:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Warlocksirix
Sep 3, 2015 12:26 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
3rdgenparts
Aug 6, 2015 09:03 AM
