Rear brakes squeaking like crazy!
Old Apr 2, 2013 | 07:31 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
Hey guys, I have an '89 IROC with rear disks and they have been squeaking for about 9 months now and I cant narrow it down. I replaced the calipers because they were seized, then replaced the rotors because the insides were worn paper thin, and i just installed new pads and replaced the outer wheel bearing..AND STILL SHE SQUEAKS! I couldnt figure it out until the other day i pulled the passenger side wheel and saw that the bracket the caliper bolts onto has some rubbing marks where it looks like the rotor is coming into contact with it. now the squeak gets faster the faster i drive, but goes away once i apply the brakes with a decent amount of force. but when i use a very light amount of pressure on the brakes i hear a loud groaning sound, but if i give a little more pressure it stops. the groaning only happens when it is light, and the squeaking is always happening when im not using my brakes.
what would cause the groaning noise, and why does it look like my rotors are rubbing the bracket?
Old Apr 2, 2013 | 10:24 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Rear brakes squeaking like crazy!
Make sure that the bolts that bolt the brackets to the rearend aren't rubbing the back of the rotor. If you have to long of a bolt there, it will rub the rotor. Not much clearance between bracket bolt and the rotor.
Old Apr 2, 2013 | 11:58 PM
Car: 1987 IROC-Z
ok, i found a few pictures on google real quick to help explain. Imagine this is the rear disk on an 89 IROC. inside the red circles is where i found some rub marks on the bracket there where its must touch the rotor, but when i have the wheel off it isnt touching at all. that is where i think the squeak is coming from....but i wouldnt know what to do about it. ill get some pictures of my own car up this weekend.
Attached Thumbnails Rear brakes squeaking like crazy!-brake.jpg   Rear brakes squeaking like crazy!-brake2.jpg
Old Apr 3, 2013 | 07:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Because of year, I assume you have a 9-bolt. On a 10-bolt, shims were often used to center the carrier over the rotor.
JamesC
Old Apr 3, 2013 | 09:16 AM
Car: 1987 IROC-Z
yes, its a 9 bolt rear end. do i need spacers or something? it never used to do this.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
