rear brake squeak when turning left
Old Apr 10, 2013 | 09:58 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Within the last couple of days my right rear drum brake started to squeak while I slowly turn left. Doesn't happen when turning right or going straight. It's not continous though, it will squeak with each rotation of the wheel. Any idea of what this could be?
Old Apr 10, 2013 | 10:02 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: rear brake squeak when turning left
Its probably a build up of brake dust in the drum. I would take off the drums and clean out the brake dust and see if it still does it. You can use brake clean or just hose it out with water.
Old Apr 10, 2013 | 10:15 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Take the wheel and drum off and take a good look.
It could also be the early signs of a wheel bearing, is it a squeek or more of a squeeky pop?
Old Apr 10, 2013 | 10:37 PM
Gsoleski's Avatar
Car: 1984 Z28
ill give that a shot. There's no popping sounds that I can hear
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
novaderrik
Aug 10, 2015 12:44 PM
Fronzizzle
Aug 9, 2015 01:15 PM
