'92 camaro parking/e-brake help
Old Apr 26, 2013 | 09:19 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
i have a '92 camaro rs, 305/auto drum rear. how do i adjust the parking/e-brake on this thing? i have an '88 camaro b4 and to adjust that there was a nut on the bracket that connected the drums to the e-brake handle, however my '92 does not have that adjuster nut, so how do i adjust the e-brake? it needs to grab sooner when pulling on the brake lever.
a side note about the equalier where all 3 cables go to, the drivers side seems to pull harder on the bar so when its just resting (or engaged) the bar is diaigol with the drivers side closer to the axle. dont now if thats normal or not.
Old Apr 27, 2013 | 06:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: '92 camaro parking/e-brake help
Originally Posted by DARKmj16
...my '92 does not have that adjuster nut, so how do i adjust the e-brake?
Your 92 is supposed to be self-adjusting.
JamesC
Old May 15, 2013 | 10:18 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Well what do ya do when the E-brake handle is pointing up towards the roof and has been doing so for so many years?...even after you replaced the whole rear drum brake set up!
Old May 15, 2013 | 10:21 PM
DARKmj16's Avatar
Engine: 305 tbi
look at the cables when dropping the gas tank and relize the cables came out of their brackets giving way to much slack!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
