Wilwood Master Cylinder Install
Old May 21, 2013 | 08:22 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Engine: 396 LT1 Stroker
Axle/Gears: Ford 9 Inch w/ 3:70 Gears
Has anyone installed a Wilwood master Cylinder in your F body? I am about to do so any im looking for tips.
Old May 21, 2013 | 09:11 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Wilwood Master Cylinder Install
You need to search before asking questions that have been covered many times over. For example here is tech article on exactly that: https://www.thirdgen.org/propvalve
Old May 21, 2013 | 09:43 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
https://www.thirdgen.org/forums/brak...-cylinder.html
had this one saved in my suscriptions.
Old May 22, 2013 | 08:56 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Tibo that is a article about installing a Prop Valve. My question was about a master cylinder. The last time I checked those are 2 different parts.
Old May 22, 2013 | 08:58 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Thank you Lone, I have installed the same Master Cylinder. I am stuck at a crossroad here. I think I might have the Lines coming out of the master going to my 1LE prop valve crossed. Im looking for a pic to see how someone else may have set it up.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
