LS1/C5 parts compatability
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
First off, let me begin by saying I have done a LOT of reading about brakes, and know that the LS1 front calipers and the C5 front calipers are basically identical, except for the method of production and the ribs go the entire distance inside to outside) instead of half way.... The LS1 front rotor is 12" and the C5 front rotor is 12.75"...
Here is my question:
Can the LS1 calipers and carriers (using the C5 conversion brackets) use the C5 pads and be mounted over the C5 rotors?
I have heard that the C5 caliper is a direct bolt-in replacement for the LS1 car, but can it go the other way?
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: LS1/C5 parts compatability
some swaps for some applications use a C5 rotor with the LS1 caliper.. i think they have a different offset from the wheel mounting flange to the face of the rotor or something that makes them a better combination for some applications, but it might just be a rotor diameter thing, i don't know.
Car: 87' IROC
John
Car: 1991 Camaro RS
Engine: L98 350 TPI
Looks like I would need to find c5 abutment brackets. Would the same go for c6 z51 setup?
Car: 87' IROC
Keep in mind the GM (and lots of OEM replacement copies) Z51 rotors are directional (curved vanes) but there is only one part number for right and left. So one side is correct and the other size runs backwards. This is how the cars came from the factory. Very stupid. For this reason, I only recommend certain aftermarket rotors when going for a Z51 setup.
John
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
