forth gen brake booster clearance isue!
Old Jun 9, 2013 | 03:42 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
hey there guys, is anyone else having trouble with clearance when you installed your booster & master in your third gen? I installed mine today and it is really close to my strut tower mount, it fits but kinda close to my liking, any info?
thanks
Old Jun 11, 2013 | 10:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: forth gen brake booster clearance isue!
hmm. I have a full fourth gen brake setup and the Founders strut mounts, so very similar to yours. My strut mounts are close to the body of the master cylinder whereas yours is close to the reservoir. Is your car at a stock(ish) ride height? My thought is that you may have too much caster (or camber I forget). I am running 4* positive which is the most my setup would allow. Maybe look into an alignment and bring the caster (or camber) in a degree or two and allow for more clearance. If you don't want to change it I would definitely look into getting a strut tower brace to prevent the tower from contacting the reservoir.
sailtexas186548
Jan 19, 2016 12:21 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
