PowerStop K1482
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
PowerStop K1482
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: PowerStop K1482
Don't do it. If your brakes are old and need servicing either replace with stock stuff or go with LS1 / C5 / whatever conversion.
Car: 1990 Firebird
Engine: 350 TBI
Re: PowerStop K1482
IMO they are not worth the price. They are still a 10 inch rotor and a tiny pad. If you can't upgrade to a larger brake system then just buy stock type rotors and pads and save your money.
Car: check
Engine: check
Transmission: check
Re: PowerStop K1482
What pound said. If your car needs rotors just get some quality solid ones from a place such as NAPA. For better braking get a better pad, such as StopTech Performance Street pads.
The pads make the biggest difference in a street car braking system.
RBob.
RBob.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: PowerStop K1482
You don't want slotted rotors on a street car. They'll just eat your pads faster. I wouldn't bother with drilled rotors on the front either. The 10.5" rotor is already small, so why make is smaller by adding holes to it.
I'd highly recommend following what I did in the fronts. NAPA solid rotors and Stillen brake pads (D-154HD). They're cheaper than the Power Stop package and you'll end up with a much nicer brake pad as well as longer life.
https://www.thirdgen.org/forums/brak...-ultimate.html
