Brake Issues
Old Jun 22, 2013 | 05:31 PM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
Transmission: 700 R4
Brake Issues
I need some help diagnosing brake issues on my 85 TA. I had almost no pressure in the pedal, the car was just barely stopping, and I've always had to pull the pedal back up with my foot after using the brakes. I thought it was the master cylinder. We put a new master cylinder on, and they're worse now. Still no pressure, and now the front calipers lock down. The pedal comes back on its own now, but the brakes don't let off.
Collapsed hoses? Bad calipers? Bad booster? I don't want to just keep replacing parts without knowing what the problem really is.
Any thoughts?
Old Jun 23, 2013 | 04:43 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Brake Issues
you say the calipers lock down, that sounds like your front hose/s need to be replaced. after time they will swell inside and cause the issue your having.
also, when was the last time you fully bled the system? if its been a good while you may have moisture in the system and that can play a part in this. bleed it till the fluid runs clear and no air.
Old Jun 23, 2013 | 08:45 PM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
Re: Brake Issues
Hoses explain the calipers, and they're inexpensive, so we may as well replace them. But I don't understand the lack of pressure. Is there a way to test the booster? I hate to replace good parts.
Old Jun 23, 2013 | 09:03 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Brake Issues
if y haven't bled the system fully or in a long while there may be moisture in the lines and that can cause issues. pop the new hoses on and do a full bleed first. if you still have pressure issues then we can address it then.
Old Jun 25, 2013 | 06:21 AM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
Re: Brake Issues
Will do. Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
