adjustable prop valve issue HELP!
Old Jul 4, 2013 | 08:31 PM
Method_z28's Avatar
Car: 92 camaro z28
I installed am ssbc adjustable prop valve. I bench bled the master twice. I am positive I have no leaks anywhere. I even replaced the link e going from the ssbc prop valve back to the rear. I cracked the rear bleeders open on the rear and I can't get any fluid to drip out. I 2 man bled it a few times and I am getting minimal air/fluid to co e out the bleeder. I tried leaving the adjustable **** in the middle....full pressure.....and full decrease pressure. What am I doing wrong?
Old Jul 4, 2013 | 08:33 PM
Method_z28's Avatar
Car: 92 camaro z28
Re: adjustable prop valve issue HELP!
Forgot.....brakes worked prior. Its a new master cylinder as well. 9 bolt disc rear and c6 Yvette front caliper set up. I haven't touched the fronts yet. All problems are in the rear.
Old Jul 9, 2013 | 08:01 PM
Pocket's Avatar
Car: 91 Trans Am
Grab a vacuum bleeder and try it again
Old Jul 10, 2013 | 03:49 PM
87350IROC's Avatar
Car: 87' IROC
Inspect to make sure you don't have any kinks in the line. If you don't, I would start by checking fluid pressure everywhere.
Install a brake pressure gauge in the rear brake outlet of the master cylinder. Do you get good pressure? If yes, move on, if no, you have found your problem.
Install gauge in the outlet of the prop valve. Do you get good pressure? If yes, move on, if no, you have found your problem.
Install gauge in rear caliper bleeder.
NORTz89
May 20, 2020 03:51 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
