still having braking issues, bigger booster?
Old Jul 14, 2013 | 05:20 PM
Casey Meyers's Avatar
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
ever since i bought my car its had poor braking with a hard pedal. all new calipers all around, adjusted the rears multiple times, prop valve spring mod and new master. its getting better, but i dont have a lot of vacuum. i thought of doing hydroboost, but want to try a new booster. pedal is firm, holds vac for a few days. about half way though the pedal gets hard. is there a bigger booster i can run? if im not mistaken, the stock is a dual diaphragm?
Old Jul 14, 2013 | 05:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: still having braking issues, bigger booster?
How much vaccum are you making? If its not enough, a larger booster wont help.
Cam specs?
Old Jul 15, 2013 | 09:27 AM
Car: 86 Z28
Engine: 385 HSR
cant remember exactly, 234 duration, 490 lift. no clue on how much vac, but when revved the pedal will go down easier. it was like that stock and the only thing left is the booster
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Warlocksirix
Sep 3, 2015 12:26 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
