LT1 rear disk swap
Old Jul 18, 2013 | 06:36 AM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
LT1 rear disk swap
Alright guys, so I bought a 10 bolt off of a guy on TGO to go on my '84 T/A, and it came with LT1 rear discs. It doesn't have the brake lines on it, as he needed them for his new rear. I know I need flex lines to the hard lines, and then I'm assuming a T to another flex so that the rear end can travel up and down.
Can someone tell me part numbers for anything that I need? I heard Ed Miller sells all this stuff, so maybe he'll chime in with a complete brake line kit for me. I've got the stock '84 calipers up front, but I'm looking to go braided on those flex hoses, as the OE ones are still on there, and I have a pull under braking, which I'm thinking might be that.
Would it be recommended to just replumb the whole brake system, or is it unlikely that the OE hard lines are causing the pull?
Old Jul 18, 2013 | 01:09 PM
Car: 1984 Trans Am
Engine: 355
Re: LT1 rear disk swap
Ok, So I guess the better question is really pretty simple. If I go on Summitt and get braided flex line that fits the stock front and rear disk application, will that fit the LT1 brakes?
Old Jul 19, 2013 | 06:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No. The PBR's have a flex line to each caliper; the Delco-Moraines only have one (and the lengths are different). The PBR calipers are virtually the same from 89-97. I'd guess you can purchase the hard lines from one of the following sites:
http://www.flynbye.com/catalog/i212.html
or
http://www.finelinesinc.com/
http://www.classictube.com/
http://www.inlinetube.com/
JamesC
Old Jul 19, 2013 | 10:31 AM
Car: 1984 Trans Am
Engine: 355
Ohhhhh, so LT1 brakes are either PBR or Delco? The guy who I got them from said he had a flex line running to each caliper, so they must be PBR.
Thanks!
Old Jul 19, 2013 | 10:34 AM
JamesC's Avatar
82-88 Delco-Moraine. 89+ PBR.
JamesC
Old Jul 19, 2013 | 11:04 AM
Car: 1984 Trans Am
Engine: 355
Yup, just did some research. Thanks man, flynbe has a complete rear kit, including flex lines and hard lines for the LT1 PBR's, fyi for anyone else who's doing this.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
