Hummer H3 Calipers
Old Feb 25, 2013 | 07:17 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Hummer H3 Calipers
I saw it mentioned on LS1Tech that H3's use 4 piston fixed calipers and they can be had quite cheap (~$150/pair). Does anyone have any info on these? I did a quick search and didn't see anything come up. I wonder if these could be a possible swap?
Old Feb 26, 2013 | 11:33 PM
87350IROC's Avatar
Car: 87' IROC
Re: Hummer H3 Calipers
Interesting. Any more info, piston size? Rotor thickness? Rotor diameter stock?
Old Feb 27, 2013 | 05:06 PM
DBLTKE's Avatar
Engine: LB9, LB9
Rotor thickness: 28mm / 1.10"
Rotor diameter: 315mm
Rotor height: 70.2mm
Caliper bore: (accurate?) 45.5mm
port: (not sure what this is) 10x1.5mm
pad: (not sure what this is) 10x.11190
pad size: 134mm x 73.5mm x 16.9mm
caliper mounting bolts are 5" center to center
I haven't been able to find any real solid info on the calipers yet.
http://ls1tech.com/forums/suspension...t-caliper.html
Old Feb 27, 2013 | 05:26 PM
87350IROC's Avatar
Car: 87' IROC
That all looks fair enough. I really don't see any advantage though compared to other options. What are you are thinking about with these?
Calipers seem roughly the same price as CTS-V / Camaro SS.
It looks like they may be easier to mount.
Old Feb 27, 2013 | 07:47 PM
DBLTKE's Avatar
Engine: LB9, LB9
I've seen the calipers as low at $62 each. I'm a tech for a GM/Subaru dealership so I can get parts for a pretty good discount too. They sparked my interest simply because they could be another option, they're possibly cheaper, and easier to mount.
Old Feb 27, 2013 | 09:45 PM
87350IROC's Avatar
Car: 87' IROC
Well I would be happy to play with one if you wanted to send one to me. Heck if you could get one to me for $62, I might even buy one.
See here for credentials.
https://www.thirdgen.org/forums/brak...brake-kit.html
Old Mar 3, 2013 | 12:14 PM
DBLTKE's Avatar
Engine: LB9, LB9
I just found that the piston outside diameter is 2.75" which is approximately 70 mm each.
Old Mar 4, 2013 | 01:29 AM
87350IROC's Avatar
Car: 87' IROC
That can't be right. That would be way to large.
Old Mar 10, 2013 | 11:03 AM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
subscribed
Old Mar 12, 2013 | 10:48 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Is the caliper aluminum or cast iron? Hard to tell in the pix I saw.
Old Mar 13, 2013 | 12:16 AM
87350IROC's Avatar
Car: 87' IROC
It sure looks cast iron in some of the pictures, but apparently it is aluminum.
Old Jul 19, 2013 | 02:09 PM
secondgenta's Avatar
Where can i find those calipers cheap?
