Brake clocking
Old Aug 15, 2013 | 03:07 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Brake clocking
I am installing a Mosier 12 bolt in my 91 RS. With this I am installing Wilwood rear disc brakes. My question is... what position should I mount the calipers (front of the car or back of the car)? I have the passenger at the 9 0Clock position as you are looking at the tire. I have to rout the lines infact I think I am going to bend the lines custom.
The parking brakes are both facing forward if I clock the calipers twards the rear of the car.
Thanks I am at a stand still till I hear from you all.
Old Aug 15, 2013 | 05:15 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: Brake clocking
Mount so the bleeder is at the highest point.
Old Aug 15, 2013 | 07:40 PM
87350IROC's Avatar
Car: 87' IROC
Re: Brake clocking
Most modern Wilwoods have bleeders on both sides.
I would clock them whichever way makes it easiest to run the parking brake lines.
Old Aug 15, 2013 | 09:47 PM
gregl316's Avatar
Re: Brake clocking
Thanks I mounted both of them towards the rear seeing that they have 4 bleeders not all of them can point up.
Old Aug 16, 2013 | 06:37 PM
gregl316's Avatar
Re: Brake clocking
With the new upgrades do you think I should put a bigger master cylinder in and a new prop/combo valve?
Old Aug 16, 2013 | 07:25 PM
87350IROC's Avatar
Car: 87' IROC
Re: Brake clocking
It depends what you want from your brakes. Compared to stock, do you want:
longer or shorter pedal travel?
more or less pedal effort?
What is the piston size on your front and rear brakes?
I always recommended an adjustable prop valve.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
