LS1 - C5 compatibilty question
Old Aug 27, 2013 | 02:09 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
quick question...if I wanted to run C5 calipers on a 12" LS1 setup (rotor) to clear 16" Z28 wheels, would I just need the conversion brackets and rotors? Are the abutment brackets interchangable, or would I need LS1 abutments, as well? Anything else I'd need?
Old Aug 27, 2013 | 07:32 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Re: LS1 - C5 compatibilty question
To run that setup, you would need to following:
-Modified Spindle
-LS1 adapter bracket
-LS1 abutment bracket
-C5 caliper
The calipers are interchangeable on the abutment brackets, but the LS1 abutment can't be used with the C5 rotor and vice versa
Frozer!!!
Jan 19, 2024 04:55 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
bryanwood74
Sep 24, 2015 09:50 PM
lt1z350
Aug 28, 2015 05:57 AM
reiderz iroc
Aug 13, 2015 04:57 PM
