1988 GTA Rear Cast Iron Caliper
Old Sep 24, 2013 | 09:37 PM
JeffD's Avatar
Car: 1988 Pontiac GTA
Transmission: 4 spd automatic
Replacing both rear brake calipers and am having a problem. When putting the new pads on there is not enough clearance to slide or even "encourage" the calipers/pads back onto the rotors. Rotors are in good shape at 1.035" with no warping. I have verified that the inner pad is flat on the dampening ring and piston, but it seems the piston needs to go in another 1/8th of an inch.
Do I need to rotate the piston 180° on the emergency brake "shaft" in order to get this needed clearance or am I missing something obvious?
Any pointers would be appreciated.
Thanks,
Jeff
junkcltr
Aug 2, 2019 11:12 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
