Putting 95 Z28 complete rear end into 83 Camaro
Old Oct 5, 2013 | 07:15 PM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
My first problem is how to remove the E-brake from the caliper. Any knowledgeable guys out there that know how? Thanks.
When I remove the rubber cap that is on the stud with a nut on the other side, there is a clip pin. Can you get new clips because it looks like you'll destroy the clip during removal.
Old Oct 7, 2013 | 03:02 PM
Strick1's Avatar
Re: Putting 95 Z28 complete rear end into 83 Camaro
Any help?
Old Oct 10, 2013 | 08:16 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
why are you trying to remove it?would this help?http://www.flynbye.com/catalog/i199.html
Old Oct 11, 2013 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
FYI: The donut (rubber damper) isn't necessary. Many cars weren't equipped with it.
JamesC
Old Oct 11, 2013 | 07:24 AM
Strick1's Avatar
We had an extra caliper with the E-brake on it and took it apart. Took the clip off and pushed the shaft through. I hope I can find a replacement clip. The rubber boot just holds in grease so the shaft and parts move freely. Then it was easy to remove the rest of the E-brake assembly. Now I can polish up the caliper which buffs out really nice. I guess the damper disc is to help with vibration.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
