rear disc e brake issue
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I recently changed from a 10 bolt disc to a 9 bolt. on the 85 10 bolt I had one fairly new replacement caliper. it didn't go on the 87 9 bolt because the threads stripped out for the brake line. so I used the two calipers that were with it.
the wheels lock up when the brake is applied. they were bled properly. the parking brake cables were put on and all adjusted. however the parking brake will not work. the cables move and tension springs at the caliper compress. I knw all the mechanics are working. it seems the actuators are not moving inside the calipers.
do I need to replace both calipers or rebuild them?
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: rear disc e brake issue
Lots of threads about this. A quick search turned this up
https://www.thirdgen.org/forums/susp...esnt-hold.html
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
