Gutted combo valve
Old Oct 21, 2013 | 09:53 AM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Gutted combo valve
Can u just remove the springs in the valve for full pressure or just the rear spring for full rear pressure
Any info would be great thanks
Old Oct 21, 2013 | 09:58 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Gutted combo valve
You could but the rear brakes would lock up before the fronts. Or. Install an adjustable valve in the rear circuit. You can bypass the rear of the distribution block completely but the brake warning light will stay on as it'll think the circuit has failed. You could T off the input to the distribution block and plug the rear outlet. Put the adjustable valve in the rear circuit. It's a great addition to the brake system.
Old Oct 21, 2013 | 10:43 AM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
I want backs stronger for sure big tire skinny in front
So I can just pull the spring out for full rear pressure and what spring the one closer to the firewell or one facing front of car
Old Dec 27, 2013 | 08:52 AM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Any pics of this
Or pics of valve mods
drptop70ss
Oct 4, 2015 09:44 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
