LS1 Brake Upgrade
Old Oct 22, 2013 | 05:59 PM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
LS1 Brake Upgrade
Question is will the Russell Brake Lines - 692370 on ebay work with a front LS1 brake upgrade on my iroc? What length front brake hoses are need and/or ideal?
http://www.ebay.com/itm/Russell-Brake-Lines-692370-/161133467102?&_trksid=p2056016.l4276
Old Oct 23, 2013 | 08:12 PM
rwstegne's Avatar
Engine: 5.7L
Re: LS1 Brake Upgrade
bump
Old Oct 27, 2013 | 10:30 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I was able to use the braided Wilwood or earls lines for our cars work fine with my ls1 brakes. I will add that I redid the brake lines, I bent my own and made a set how I wanted them routed so the length may be an issue....
Old Oct 28, 2013 | 08:27 AM
rwstegne's Avatar
Engine: 5.7L
Do you have any pictures of our rerouting for the lines and new hoses? Just trying to get ideas from this Xmas brake upgrade.
Also, any issues cutting off the wheel stops on the spindle and arms? I mean, is the only issue the wheel rubbing on the wheel well? Do you know of anyone redesigning a new wheel stop assembly?
Old Oct 28, 2013 | 06:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
There is no issue with removing the wheel stops on the spindle(s) because the bracket will act as the new wheel stop. No need for a new design. Cut them off and grind the area smooth.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
