P/N NM1985 and ZY12263 Master cylinder
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Hey all,
I just got this master cylinder pn NM1985 or ZY12263, new from autozone. its supposed to be a performance master cylinder for a 86-92 5.7 car.
I need a 4 wheel disc master and I hope this is it.
Any ideas? I searched these numbers and couldn't come up with much.
I just switched to Ford explorer rear disc with my 12 bolt moser. They said the piston size is the same as factory and that my master is probably bad.
any ideas? part number correct???? thanks
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: P/N NM1985 and ZY12263 Master cylinder
What is a performance master cylinder?
What problem are you having?
The stock master cly should work fine, with either a 1LE or an aftermarket adjustable prop valve.
