hello need some brake proportioning valve
Old Jan 16, 2014 | 10:22 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ok i have a brake proportioning valve off a 1989 trans am gta had a 9 bolt PBR rear brake setup .well my camaro is a 1992 rs i have a built 9 bolt now with 94 bpr brake setup on it now ...well my ? is i really about that there was alot of info out there i know they changed the threads on the rear line but when .was it from the swap of the 88 iron brakes to the newer 89 pbrs or did they change it again after 89?? and help is a big thanks bc there seams to be alot of wishy washy info
i have pix if any one wants them it has marking MB on a tag and MB 35KH 270 9 marked into it
Old Jan 19, 2014 | 06:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: hello need some brake proportioning valve
From Dan Burke's page concerning the combination valve:
1st design: M1.0 tube nut threads (for 1982 to early 1989 applications)
2nd design: M1.5 tube nut threads (late 1989 through 92).
Either of the valves can be purchased below:
http://www.flynbye.com/catalog/c1_p1.html
You may also find the 10-Bolt FAQ useful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
