Afraid to ask, but, rear discs...
Old Feb 3, 2014 | 02:23 PM
jedidethfreak's Avatar
Okay, so I don't have it YET, but I'm eventually going to be getting an '86 TA roller, with the intention of swapping out the 10-bolt to a Moser 12-bolt with Wilwood rear discs with p-brakes.
My question is, if I get a master cylinder out of a TA for four-wheel disc, do I still need a proportioning valve? I know I'd need one if swapping from rear drum to disc, but - as I understand it - that's due to the master cylinder itself. However, I ALSO read that the rear drum MC is apparently a GM-recommended install if you don't like the harder pedal feel from the four-wheel disc MC.
So, in this case, would buying the four-wheel disc MC by itself be sufficient, or would I still need a proportioning valve?
Old Feb 4, 2014 | 06:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Afraid to ask, but, rear discs...
Check the 10-Bolt FAQ for information about master cylinders and combination valves.
JamesC
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Steve78LT
Feb 24, 2016 12:15 AM
neekolzun
Aug 24, 2015 04:59 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
