ebrake
Old Feb 2, 2014 | 11:20 AM
patriots781's Avatar
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
ebrake
I'm trying to figure out why my ebrake isn't working I'm jacking the car up anyways to put new tires and rims so I was jw is it located behind the rear left or right I looked on google and did a search here and can't seem to find it so anyone know?
Old Feb 2, 2014 | 08:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ebrake
After reading the above several times, I'm still confused. Stated simply, what's your question?
JamesC
Old Feb 2, 2014 | 11:33 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: ebrake
There needs to be a little more info provided... Disc or drum car? The e-brake system is pretty simple. A cable runs to the axle and puts manual pressure on to the drum or rotor.
Old Feb 4, 2014 | 12:04 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: ebrake
The answer to your question is: BOTH.
Look at this thread and check out the picture that Chevy86 IROC-Z posted. It shows you all that you need to know:
https://www.thirdgen.org/forums/brak...ing-brake.html
Zepher
Brakes
111
Jan 4, 2025 10:38 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
MasterEvilAce
Aug 29, 2010 02:01 PM
theSteve
Aug 21, 2003 04:37 PM
TekViper
Mar 27, 2003 07:36 PM
