rear end ?? 9 bolt or 10
Old Feb 9, 2014 | 05:35 PM
blue78rs's Avatar
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Axle/Gears: ??????????????
Before you send me to a link, hear me out. I just got an 84z28 for basically free, sight unseen. Well it showed up and low and behold it has a 9 bolt disk, I ran all the rpo codes this car did not come with it. So it has been changed. For the past year I have been getting parts together to build my 91rs drum rear. I got the posi and pbr disk brakes from a 4th gen. with 273 gears. Now to my question Should I just keep the 9 bolt with the disk/ and if I do what years do I need to tell the parts shops so I can get the right stuff to rebuild the brakes. Or can I put the disk brake setup on my 10 bolt?? Sorry if this is a dumb question.
Old Feb 9, 2014 | 06:55 PM
Twin_Turbo's Avatar
Re: rear end ?? 9 bolt or 10
9 bolt backing plates won't fit the 10 bolt. Does the 9 have the crummy iron delco moraine calipers (staggered setup) or the later pbr alu ones?
Old Feb 10, 2014 | 03:48 PM
blue78rs's Avatar
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
I have the iron ones, by your description im guessing their not good?
Old Feb 10, 2014 | 03:55 PM
Twin_Turbo's Avatar
you guessed it, nothing but trouble
Old Feb 10, 2014 | 04:07 PM
blue78rs's Avatar
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
off to the classifieds. Thank you sir.
Old Feb 19, 2014 | 07:38 PM
blue78rs's Avatar
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
so i need to ditch the 9 bolt and keep the 10?.
Old Feb 19, 2014 | 07:39 PM
blue78rs's Avatar
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
what should I ask for the 10 bolt
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
