E brake adjustment?
Old Feb 15, 2014 | 09:17 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
E brake adjustment?
swapped to a 9 bolt 2 years ago... got all new cables. still got no ebrake... too much slack. any ideas? is it adjustable?
Old Feb 16, 2014 | 12:33 AM
Mark RWC's Avatar
Re: E brake adjustment?
The is an adjustment above the drive shaft were the two cables from each brake meet. It is hard to see unless the car is on stands.
Old Feb 16, 2014 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Insomniac's 91 wouldn't be equipped with the tunnel-mounted adjuster.
JamesC
Old Feb 16, 2014 | 07:20 AM
insomniac's Avatar
Engine: 5.7 L98
maybe thats my problem? i dont have above adjustment... the cables i got were from an 87 to match the rear.... so what should i do?
Old Feb 16, 2014 | 09:56 AM
JamesC's Avatar
You'll need to swap in the adjuster and perhaps the parking brake pull mechanism. I search may provide more info.
JamesC
Old Feb 17, 2014 | 11:06 AM
Justinramsey's Avatar
Car: 1987 Camaro sport
Engine: 2.8l v6
I am having the same issue, I have a 87 sport Camaro. and the ebrake just wont hold the car back. I know I need to tighten the line to remove the slack, but im not sure if I need to take apart my console to get at the lever or go underneath the car and start there. any ideas?
Old Feb 17, 2014 | 01:40 PM
JamesC's Avatar
On an 87, the adjustment is made under car.
JamesC
Old Feb 17, 2014 | 01:47 PM
insomniac's Avatar
Engine: 5.7 L98
so is there just no adjustment on a 91?
Old Feb 17, 2014 | 03:08 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
this is the exact problem I posted in this section last week. Get some cable clamps to shorten the cables if you cant or don't want to get the adjuster.
Old Feb 17, 2014 | 03:11 PM
insomniac's Avatar
Engine: 5.7 L98
http://www.boaterbits.ca/stainless-s...lamp-1-11.html
something like that? and where should i put them?
Old Feb 17, 2014 | 08:52 PM
JamesC's Avatar
90-92 cars are self-adjusting.
JamesC
Old Feb 17, 2014 | 11:13 PM
Claybraham's Avatar
Car: 91 rs camaro hard top
Engine: 350 vortec
Transmission: 5 speed. T5
Axle/Gears: 3.70 gear 9 bolt posi. disc brakes
i recently swapped to a 9 bolt 3.70 gear rear end with disc brakes from a 87. im suppose to be getting the e brake cables in the morning to go from drums to disc... i have a 91, so maybe when i get in there to swap the e brake cables out ill find out something and get back to you..
might just have to get cable clamps like banks4004 said
Old Feb 17, 2014 | 11:52 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
I have only heard of the cable clamp idea for the record. I don't see why it wouldn't work and I was going to do it but I recently took apart my brake lever to lube it and when I put it back in it works. Maybe it self adjusted or something. Not sure how the self adjustment works
Old Feb 18, 2014 | 06:43 AM
insomniac's Avatar
Engine: 5.7 L98
1) how does a self adjuster work?
2) where do you put the cable clamps?
Old Feb 18, 2014 | 06:59 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
the cable just has to be shorter so anywhere on the cable that doesn't interfere with anything during the full travel should be fine
Old Feb 18, 2014 | 09:14 PM
Claybraham's Avatar
Engine: 350 vortec
My cables didn't come today :/. Truck is running late due to the weather here. I was thinking about getting a adjust mount off a 87 or older car. If I use the cable clamp idea, I'll try it out where the two lines come together at the mount, where it turns into one cable.
Not to hijack but Did you have to get a new prop valve? If so do you have the part number? I still need to do that cause I had drums then went to disc, and now my back brakes aren't working as they should. Thanks!
Old Feb 19, 2014 | 06:29 AM
insomniac's Avatar
Engine: 5.7 L98
yes i did have to get a new prop valve, dont remember the number tho sorry. i found a guy selling one from a disc/disc car at the time.... not 100% sure if you absolutely have to change it tho. but if i remember correctly if you dont change it the back wheels lock up sooner because the drums require more pressure... someone else may want to chime in on this. Im not 100% sure
Old Feb 19, 2014 | 07:08 AM
JamesC's Avatar
Check out the 10-Bolt FAQ (makes no difference if you have a 10-bolt where the brakes are concerned as they're the same) for info about master cylinders, combinations valves and so on.
JamesC
Old Feb 19, 2014 | 07:08 PM
Claybraham's Avatar
Engine: 350 vortec
Ok thanks! I had a 10 bolt drum and went to a 9 bolt disc. I barley have any brake pressure in the back at all. As far as getting my disc e-brake cables, they still have not came in :/
Anyways, did you find out a solution to the problem your having?
Thanks agian!
Old Feb 19, 2014 | 07:43 PM
Claybraham's Avatar
Engine: 350 vortec
Ok, so I've been searching and Ive kinda confused my self.... So my car is a 91, the rear end with disc brakes I put in it is from a 87. So do I need the prop valve for the year of my car? Or the prop valve for the year if my rear end? Sorry!! I think I'm over thinking this... I think I need the one for the year of my car = 10164112.
Old Feb 19, 2014 | 07:44 PM
insomniac's Avatar
Engine: 5.7 L98
if i remember correctly you need one from a 91 or 92 the 87 i believe threads in differently
Old Feb 19, 2014 | 07:51 PM
Claybraham's Avatar
Engine: 350 vortec
Yeah I think this is right. http://www.flynbye.com/catalog/i160.html
Old Feb 19, 2014 | 08:47 PM
JamesC's Avatar
82-88 cars have Delco-Moraine calipers, the 89-92 cars have PBR's. The two caliper types have different combination valve requirements. The issue is that the correct valve for the 87 won't fit the 91 as the threads are different. Again, check the FAQ for specific info on sizes.
Perhaps your best bet under the circumstance is an adjustable after market valve.
JamesC
Old Feb 20, 2014 | 04:51 AM
Claybraham's Avatar
Engine: 350 vortec
JamesC
Yeah that's what I found last night in a search. Still looking for a part number and where I can get a adjustable valve. Do you know? Thanks!
Old Feb 20, 2014 | 06:16 AM
JamesC's Avatar
Search Summit and/or Jeg's for the valve.
JamesC
Old Feb 20, 2014 | 01:31 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
I swapped a disc 89 diff into my 90 (upgrading from drums) and swapped the valve from the 89 car at the same time. It threaded right in for me, piece of cake. So presumably an 89 valve would work with 89-92 cars but this is just my experience.
Old Feb 20, 2014 | 02:10 PM
JamesC's Avatar
You got lucky.
1st design: M1.0 tube nut threads for 1982* to early 1989 applications
2nd design: M1.5 tube nut threads for late 1989 to 92 applications
*Some early 80's thirdgens were SAE instead of metric, so be aware.
JamesC
Old Feb 20, 2014 | 05:50 PM
Claybraham's Avatar
Engine: 350 vortec
So this is what I'm coming up with to fit my 91. I hope this is right
http://www.jegs.com/p/JEGS-Performan...55192/10002/-1
Nope not right. I need metric and this one works with sae :/
deracer
Apr 11, 2016 12:04 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 4, 2015 07:11 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
