Brake issue
Old Feb 18, 2014 | 06:48 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Brake issue
I bought my camaro about 2 and a half months ago and the brakes were great they are stock but they were firm and seemingly in great condition. So this morning I drove 20 miles to school and there was nothing wrong parked the car and went to class. So fast forward 8 hours and I come back out I started the car let of the parking break and backed up I immediately noticed something really wrong. The pedal went halfway to the floor now and I looked down at the tack and the brake light was still on my question is what happened? what failed? And most importantly How much Lol? jk
Old Feb 18, 2014 | 10:12 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Re: Brake issue
anyone?
Old Feb 19, 2014 | 05:15 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Brake issue
Can you see any fluid under the car? My guess initially would be you sprung a leak. You may have to get the car up in the air and get under it. Follow the lines from the master cylinder back to the wheel cylinders (pull the drums).
Old Feb 19, 2014 | 09:37 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Re: Brake issue
Ok should I go to a shop or attempt this myself I am a little hesitant since I dont want to break anything. I do not want to go barreling down the road not being able to stop
Old Feb 19, 2014 | 12:37 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: Brake issue
You can check your fluid level to see if it's a leak. Pump the brakes a few times and see if the level is lower. You should be able to see some leakage though. A change that quickly is probably a leak though, so figuring out where should be your priority. I wouldn't drive it like that btw, not unless you have to.
You can probably fix it yourself, as the brake system is usually just requires a few wrenches...or vice grips
Old Mar 14, 2014 | 02:10 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Re: Brake issue
I took it to a shop and it turned out to be a rusted through brake line they replaced it for $90 dollars Thanks man
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
