On and off brakes
Old Feb 22, 2014 | 08:43 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
On and off brakes
I just got done replacing everything.
1 C5 brakes up front with braided ss lines
2 Wiwood "dyno lite rear brakes"
3 Willwood 1" bore Master cylinder
4 Wilwood adj prop valve
5 Booster
6 all vac lines
I still have a problems.
A. My peddle is there sometimes and sometimes not. If I quickly pump it they are there
B. I hooked up the brake lite on the prop valve and now everytime I apply the brakes the lite comes on.
Any one out there have any answers or Ideas
Old Feb 28, 2014 | 05:05 PM
gregl316's Avatar
Re: On and off brakes
The guys at Willwood said that is caused by the back brakes and a "C" clip axle. Called "Break Check" from the axles pushing the pads out in the turns. They said it can be fixed with a "C"clip elimitator kit to stop the axles from floating in the brakes.
I guess I am going to live with it.
Now I hooked up the brake lite and it comes on every time I hit the brakes. Why does that tell me?
Old Mar 30, 2014 | 04:53 PM
gregl316's Avatar
Does anyone have a fix for this? The guys at wilwood said "C" clip elemination clip. Also why is the brake lite coming on when i apply the brakes.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
