1le hubs and studs
Old Mar 18, 2014 | 10:48 AM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
1le hubs and studs
I am going to make a set of hubs and was wondering where I can get a set of extended studs needed to install my c4 rotors ?
Also does anyone know the exact diameter needed for 1le hubs?
Thanks!
Old Mar 18, 2014 | 12:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1le hubs and studs
If they have the same knurl as the non-1LE hubs these are what I used:
Studs: 10 pcs, napa 6411581 cross reference to dorman 610-323
54mm long, 0.509 knurl with an 8mm shoulder.
RBob.
Old Mar 18, 2014 | 03:34 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Thanks. That helps alot. I have found also that the diameter of the machined 1le hub needs to be 5.9-6 inches for a brake upgrade.
Thanks again.
Old Mar 19, 2014 | 07:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I misunderstood your second question. For the final fitment of the rotor to the hub, the outer corner of the hub gets a decent sized chamfer on it. This allows it to clear the inside of the rotor without turning to whole OD of the hub down.
Once you start to dry fit the rotor and hub, why this is done will be apparent.
RBob.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
New2Chevy
Sep 28, 2015 12:35 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
355tpipickup
Sep 13, 2015 11:35 PM
