92 10-bolt PBR brakes to 9-bolt with iron calipers
Old Mar 21, 2014 | 06:43 PM
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
I've searched but can't find a definite answer. I have a 87 GTA with the 9-bolt rear and the iron calipers. I got the complete PBR brake setup from a 10-bolt 92 Camaro. Backing plates, emergency cables all the way up to the handle, etc. Is this a direct swap from a 10 to 9 bolt? I saw something about special backing plates but do I need any if I have the ones from the 10 bolt? Thanks for any help.
Old Mar 21, 2014 | 07:47 PM
L98GTA87's Avatar
Car: 1987 Trans am
Re: 92 10-bolt PBR brakes to 9-bolt with iron calipers
Found my answer. The plates can be swapped but have to be re-drilled.
Old Mar 21, 2014 | 08:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Or you can purchase the correct plates.
JamesC
Old Apr 18, 2016 | 09:33 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I always thought the 89-92 10-bolt PBR backing plates were a direct swap for the 82-88 Iron Caliper backing plates. WRONG !!
The holes in the 10 bolt PBR plates are already slotted and I didn't feel comfortable drilling out any more material to try and make the "newer" PBR brackets fit the 82-88 Disk Brake axle housing. Drilling a few holes is easy,... being sure the backing plate is centered around the AXLE and the fact that those backing plate holes were already slotted made me decide not to even bother hacking it together.
Old Apr 18, 2016 | 09:41 PM
JamesC's Avatar
Here's what I used on my 85. No slots.
JamesC
Attached Thumbnails 92 10-bolt PBR brakes to 9-bolt with iron calipers-screen-shot-2016-04
Old Apr 22, 2016 | 07:31 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I swapped a set of 10 bolt backing plates left to right and re-drilled them for the 9 bolt pattern, no slotting necessary
Old Apr 23, 2016 | 01:36 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
this is a shot of my plates..that came in with my 9" from curry ent. custom...lol
dbrochard
Sep 19, 2015 08:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
