Help...Rear disc brake nightmare..
Old May 3, 2014 | 08:49 PM
fire.chicken86's Avatar
Car: 87 trans am
Engine: 5.o tpi
Transmission: 5 speed manual
Axle/Gears: ?
I have an 86 firebird with 99 Camaro rear end. The car is a project car and has been sitting idle for a couple of years but has been started up and driven around the block every couple of weeks. Now we are trying to get her up and running and just put new rotors and brake pads on the rear. Tried bleeding the brakes now the pedal is mushy and the rotors wont turn. Not to smart on brakes any help would be awesome.
Old May 4, 2014 | 11:09 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Help...Rear disc brake nightmare..
Park brake stuck on?
Old May 4, 2014 | 01:02 PM
Car: 87 trans am
Engine: 5.o tpi
Axle/Gears: ?
Nope.I wish it was that simple.
Old May 5, 2014 | 06:55 AM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Will they turn if you open the bleeders?
Old May 5, 2014 | 04:23 PM
Car: 87 trans am
Engine: 5.o tpi
Axle/Gears: ?
yes
Old May 5, 2014 | 05:00 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Bad master
Old May 6, 2014 | 11:10 AM
Car: 87 trans am
Engine: 5.o tpi
Axle/Gears: ?
Well after taking off the calipers and re installing them it appears that we just need do bleed the lines really good and I do mean good, it took alot longer than normal but again the car has been sitting for a while. Now for the front which is the original 86 front,Wish us luck.
Numbah-1
Sep 12, 2015 08:57 PM
64Chief
Sep 12, 2015 08:05 AM
drb930
Sep 9, 2015 10:53 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
