brake pads for 9 bolt axle
Car: 1989 Iroc Z
Engine: 5.7 L98 G92
I was out and checked the brakes on my Iroc and the rear pads are pretty well worn out.. Car has a 9 bolt disc brakes....Where do I go to look for pads? Were the pads used on any other GM vehicle? Also any part numbers for say raybestos or Napa type places
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: brake pads for 9 bolt axle
EDIT: Oops, sorry. In 89 you should have alum PBRs. That said, they too are the same as the 10-bolt (90-92).
JamesC
Car: 1983 Z28
Engine: 385 Fastburn
If it's the delco brakes (where one is on the calipers is on the FRONT of the rotor and the opposite side is on the BACK of the rotor) then they should take the same pads that are used on the front. At least this is the case with my '83 Z28. I have a 9-bolt disc rear from (I think) an '87 IROC and it just so happens that I now use the exact same pads on all 4 wheels.
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
