C6 Adapter bracket fab question.
Old May 24, 2014 | 07:12 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
So I found the specs for the 1/2" steel plate to do the 12.8-inch C5 fronts, got the steel, got them laid out and ready for machining, then I learned about C6 13.2-inch brakes. My question is, does anyone know if I can just move the holes another 0.200-inch out?
Old May 26, 2014 | 10:05 AM
cosmick's Avatar
Re: C6 Adapter bracket fab question.
I'm getting information that the bracket doesn't need altered because of the caliper carriers being different. Makes sense to me. GM wouldn't want to change a costly part when they could change a cheap part.
Old May 29, 2014 | 02:01 AM
87350IROC's Avatar
Car: 87' IROC
Are you referring to the 13.4" Z51 brakes. I am not aware of a 13.2" C6 rotor. If Z51, then yes, if you use the Z51 carrier, there is no need to modify your bracket.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
Abubaca
Sep 20, 2015 09:35 PM
romcjr
Sep 17, 2015 05:18 PM
Ian Irvine
Sep 4, 2015 08:08 AM
