Wilwod prop valve install
Old May 27, 2014 | 03:50 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Anybody here change their factory Disc proportioning Valve to a adjustable one?I was reading the tech article on removing the factory prop valve and putting in a Wilwod one for the back brakes.Does this setup work like the tech article States?
Old May 28, 2014 | 12:17 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Wilwod prop valve install
I've done it and it's great. I think the best way to do it is to T off the rear brake line before the stock prop valve, plug the stock rear output and run the T to the adjustable valve and then to the rear brake line. This way preserves the brake failure warning light.
Old May 28, 2014 | 07:41 AM
Steve Mack's Avatar
Car: 87 Iroc
Thanks Base.I would like to delete the stock prop valve.Even though keeping the brake warning light would be good.
Old May 28, 2014 | 11:37 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
If you're going to install an adjustable valve for the rear brakes you don't need to touch the prop valve. The prop valve only affects the rear brakes anyway so by installing a separate adjustable valve you are by-passing the stock valve. You plug the rear brake distribution block output and if you've T-ed off the input you still have the pressure to stop the brake fail warning light coming on. Or you can remove the brake buldb from the cluster!
Old May 29, 2014 | 12:37 PM
Steve Mack's Avatar
Car: 87 Iroc
Thanks for the info Base.
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
