Brake loss due to headers?
Old Jun 15, 2014 | 10:18 PM
89gta22's Avatar
Car: 1989 Trans Am GTA WS6
Engine: 5.7 350 TPI
Transmission: 700-R4 from Raptor
Recently I installed Edelbrock TES headers on my 1989 Trans am 5.7.
The other day while testing my car I experienced catastrophic brake loss just as the car hit ~220 degrees on the dash. Brakes suddenly dropped to the floor with minimal to no stopping power at all in the drivers side front wheel and partial/no braking on the pass side front wheel (I knew this because pushing the pedal to the floor caused the car to pull to the right side. Luckily I was able to roll to a stop using the e-brake but none the less the experience was troubling. As soon as the car cooled off for 30 minutes, the brakes were back to normal.
After checking the entire brake system it was clear that there were no leaks and the fluid level seems to be about where it was. However I did notice that the driver side brake lines running up to the master cylinder comes VERY close to the headers (maybe less than 3/4" away). I suspect that the heat may have actually vaporized the brake fluid causing the sudden loss of braking.
Has anyone who installed headers in their car experienced this and what are some of the possible remedies/solutions to keep it from happening again. My car rarely gets up to 220 but it was a hot day and I hope to drive it throughout the summer heat so I need to be sure this doesn't happen again!
Old Jun 15, 2014 | 11:12 PM
Joe Tag's Avatar
Re: Brake loss due to headers?
Troubling indeed. I would consider wrapping the headers, rerouting the brake lines or both. I checked my headers with an infra red gun at 500*+ while idling after a ride. Will be much hotter in hard driving. I could believe it would boil and cause issues. A quick google shows dot 3 boiling a little over 300.
Old Jun 16, 2014 | 08:24 PM
Pocket's Avatar
Car: 91 Trans Am
Boiling brake fluid sure is fun
Move the lines to the other side of the steering shaft and that wont happen again. Be gentle on the bends, dont need any kinks. This is standard stuff for headers
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
