Rear disc conversion
Old Jun 30, 2014 | 08:15 PM
84 zee's Avatar
I have a rear end from third gen with drums looking to convert to disc, what's needed and were to buy it . Any help would be appreciated.
Old Jul 1, 2014 | 10:15 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Rear disc conversion
There is a search function that should find you some threads. You could also try looking at the conversion kits flynbye.com has. They're not real cheap but it should be one stop shopping for which set up you decide to go for. You need a bracket that bolts to the axle tube to hold the caliper bracket, calipers, rotors, redo a couple brake lines and emergency brake etc. If you look at the flange on your axle you'll see how the conversion bracket on flynbye fits.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
