Brake booster problem?
Old Jul 1, 2014 | 05:19 AM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
I am just curious if the brake booster should "hold back" a little when pushing the brake pedal fast under driving??
I have 87 Camaro with the stock brake booster still running. And when I am driving the car and need to hit the brakes quickly there is a lot of force on the pedal. I can also head a "breathing" sound like when you deflecting something.
Is this normal?
I just feel that the brake booster on all other cars I have owned feel different. They are more accurate when "emergency breaking" or breaking quickly.
Old Jul 1, 2014 | 08:15 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Brake booster problem?
Needs to be replaced. My '91 Formula recently came up with that same problem. Brakes were hard and vacuum was bleeding from under the dash where the push rod goes into the brake booster. Replaced it with a used one and all is back to normal. Good luck.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
