Baer brake kit. Rears wore faster than fronts.
Old Jul 9, 2014 | 08:34 PM
winger67's Avatar
Got about 30k on a Baer kit front and back. Rears were converted from drum and while I have plenty of front pad left, the rears are worn. I didn't do anything with the combination valve when I installed it. Reading up it looks like I should have changed the metering valve. Do I need to buy a whole new combination valve or is there a way to modify what I have? If I have to buy a combination valve, I'm looking for recommendations on a source or part number.
Also thinking of going from the 12" to 13" rotors. Is Baer the only source for the brackets?
Old Aug 1, 2014 | 01:42 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Baer brake kit. Rears wore faster than fronts.
I would think the prop valve is ur problem get one from a 88-92 1LE car and it should solve the problem
Old Aug 1, 2014 | 04:51 PM
winger67's Avatar
Thanks! Will look for one.
Old Aug 1, 2014 | 06:31 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Check Lukeskaff.com and/or flynbye.com or bigbrakeupgrade.com for brackets etc.
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
