Vacuum Test
Old Sep 22, 2014 | 06:09 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Vacuum Test
Iam having a problem with my brakes can I take a vacuum test without the car running an if so how is it done. Thanks
Old Sep 22, 2014 | 07:11 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Vacuum Test
In short, no (unless you have an auxiliary vacuum pump as the vacuum source). Can you be more specific about what you're wanting to test though? Are you wanting to measure the vacuum from the source (engine or aux. vacuum pump) or are you wanting to verify the booster, check valve or hoses aren't leaking?
I'm going to assume you want to measure vacuum going to the booster from the source. Insert a T fitting between the booster and the source to measure the vacuum with a vacuum gauge/tester.
Old Sep 23, 2014 | 03:34 PM
Lurbie's Avatar
Car: 89 Camaro
Re: Vacuum Test
If your engine is not running you won't be able to measure your vacuum to the brakes because the engine is what creates the vacuum. Get your engine running first then use a vacuum tester as described above to measure how much vacuum you have.
gta892000
Aug 11, 2019 11:16 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
85 Jimmy
Sep 30, 2015 07:56 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
camarohelp
Sep 12, 2015 05:45 PM
