Bracket Name or Size?
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Does anyone know the name or size of the bracket that holds the hard line to the flex line. My new 12 bolt has none and I have to source them. They are bolted to the lower control arm bracket.
Thanks,
Brian
Thanks,
Brian
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Bracket Name or Size?
Brake Line Mounting Bracket is what it's called, size would depend on the hose going through it.
Car: 87' IROC
Hey Brian,
I imagine you can probably find them by providing the picture you took to one of the sponsor thirdgen used parts shops.
Does your new 12 bolt even have the provisions for these types of brackets?
I usually just build my own for these types of brackets.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Wow, I made my own but nothing like that. Just some angle iron.
Car: 87' IROC
Linson
Sep 21, 2015 01:08 PM
Hello, Michael
Sep 11, 2015 01:10 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
