Brake Pressure Gauge
Old Oct 10, 2014 | 08:38 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
My brakes are terrible. I just converted to manual due to low vacuum (cam) and brakes barely stop the vehicle at slow speeds. Was looking into further troubleshooting and using the gauge below but I don't see how this would screw into the bleeder port. What are you guys using to check pressure at the caliper? Is there a 12" flex line available that will adapt to this gauge and screw in to the bleeder port?
http://www.summitracing.com/parts/ss...FUuRfgod75IAXA
Old Oct 11, 2014 | 10:04 PM
87350IROC's Avatar
Car: 87' IROC
Re: Brake Pressure Gauge
I'm not sure what you mean. The link shown shows a bunch of adapters. Basically you unscrew the bleeder and screw in the adapter and gauge. You will also need to bleed the setup which might be a bit messy.
Old Oct 11, 2014 | 10:27 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
There's absolutely no room to screw in the gauge, strut is in the way. Would need a low profile 90 deg fitting with a flex line to adapt to gauge.
Old Oct 11, 2014 | 10:44 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
You know, after thinking this a bit... guess you could remove caliper, install adapter and gauge, then hold caliper in place on rotor while someone else pressed the brake pedal to obtain pressure. Yep, this would work!
Old Oct 12, 2014 | 12:28 AM
87350IROC's Avatar
Car: 87' IROC
True, that would work. Good thinking. I did not realize you were using OEM calipers. Kudos to you for actually using a gauge.
John
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
