Warped rotors
Old Dec 9, 2014 | 12:50 PM
acdcfan37's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Open Diff
Warped rotors
I have a 91 rs that is constantly warping the rotors. Any one else have this problem? Or a solution? Ive tried different rotors from different companies and same thing every time.
Old Dec 9, 2014 | 01:24 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Warped rotors
Replace the calipers and slide bolts. Make sure you grease the new slides lightly on install. Probably should replace the rubber hoses too. Warped rotors are caused by too much heat, usually from a sticking caliper that keeps the pads in contact with the rotor instead of letting them pull back slightly when you release the brake pedal.
Maybe try some better pads too. Sometimes with cheaper pads, they can leave a buildup of pad residue on the rotors making them seem warped.
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
