LS1 master cylinder
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
LS1 master cylinder
Heh everyone i got a question can the LS1 master cylinder work with a 3rd gen booster also what prop valve do you guys use with it. I have a 89+ prop valve and was wondering if that will work
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 master cylinder
It will work but the lines from the master to the booster need a little tweaking.
A 1le valve or 88 amd later disc/disc valve should be fine.
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I had cut off the mounting bracket to the prop valve. It made tweaking the lines much easier
Engine: LR4 4.8
Ok looks like im gonna purchase a 98-02 master clyinder are they all the same bore size from 98-02 or should i go with the 2000-2002 style or just get a 98-99
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Mine went on with minor tweaking. Been that way for 4+ years now. I also have a 91 prop valve.
