Can someone please help me identify what year rear brakes these are?
Old Feb 4, 2015 | 09:02 PM
Prime's Avatar
Car: 91 Firebird Vert
Engine: LO3
Here is the deal, we have a 91 Firebird convertible that came stock with a drum rear end. At some point in the cars life before we got it someone swapped in a disc rear. I am not sure what year rear it is and need to find out so I can get the right soft lines, discs, pads, and hardware. It is a 10 bolt rear and has large, heavy calipers. One caliper is rear facing and the other is on the front side of the axle. I have attached a pic of the brake assembly, thank you in advance for any help in sorting this out.
Attached Thumbnails Can someone please help me identify what year rear brakes these are?-vert-rear.jpg
Old Feb 5, 2015 | 06:05 AM
Re: Can someone please help me identify what year rear brakes these are?
That's the 82-88 setup.
What a shame.
Old Feb 5, 2015 | 07:31 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Install the recall kit if you intend to keep them. And use your parking brake.
Old Feb 5, 2015 | 08:33 PM
Prime's Avatar
Engine: LO3
Thanks for the help. I'll order the parts as if they are for an 87 Firebird. I was told to use the parking brake regularly or it will make the calipers go bad so we do. The calipers seem to work smoothly but given their age and the time they spent sitting I may ahead and replace them, from what I have read earlier the remans should have the "recall kit" already installed, I hope this is true.
Old Feb 6, 2015 | 07:22 AM
That year/model should do the trick.
AFAIK remanned, or even brand-new, calipers don't include the "recall kit". Not sure why, but w/e. Best to plan on installing it yourself.
Old Feb 17, 2015 | 12:42 PM
Mickeyruder's Avatar
Car: 91' camaro rs
Engine: Sbc 327
Axle/Gears: Stock 10 bolt w/posi 3.90 gears
Hi, not trying to take you're thread over but I was wondering what the recall kit is? And why it's needed? Thanks!
Old Feb 17, 2015 | 02:01 PM
naf's Avatar
naf
The recall kit fixes issues with the saggy brakes that otherwise keep them from consistently self adjusting. It includes redesigned pistons and other hardware. You may have to search for the part #, or I may be able to find it later.
Old Feb 17, 2015 | 04:02 PM
Car: 91' camaro rs
Engine: Sbc 327
Oh that would help if you could. My car is a 91' rs with 10 bolt drums. I bought a disc brake setup off Craigslist off an 87' bird. Seems pretty straight forward on taking all the drum brakes off but from there I may need guidance. The kit came with the backing plates? That look like a dust cover, junk calipers I need to use as cores(cast iron ones), old rotors, and some old lines and bolts. If someone could point me in the direction on procedure for doing this would be awesome!! Eventually I'll go with some pbr or similar setup when I can afford to. By the way when I was on oreily autos website they showed the exact same calipers I have but also some aluminum ones. I wonder if the aluminum ones are better and if they bolt right up to my backing plates?? Thanks!!!
Old Feb 17, 2015 | 04:46 PM
naf's Avatar
naf
Neither disc set up will bolt on to a drum rear without adapter brackets. By the time you pay for everything to do the swap right, the $120 or so that reman PBR's will cost will be insignificant. You'll need the rebuild kit (around $50) and a new mc/prop valve to maximize the effectiveness of the saggys. The PBR's can be used with the drum mc and prop.
Even without changing the mc and prop you'll have $80ish in brackets, $50ish in rotors, $30ish in pads, another $40-80 in brake lines and cables. The $70 or so to buy the reman PBR's vs the rebuild kit is a small % of the overall cost and they work.
Old Feb 17, 2015 | 05:29 PM
Car: 91' camaro rs
Engine: Sbc 327
Thanks for the info. I do already have the adapter plates for disc brakes, the cast iron ones. I have rotors but like I said my calipers are junk. I paid less than $100 for the stuff. I can use the calipers as a core charge. But I was wondering if the oreilly brake best remaned aluminum calipers are good or comparable to pbr? And will they fit my adapter plates? I'll try and post pics of what I have.
Attached Thumbnails Can someone please help me identify what year rear brakes these are?-image.jpg
Old Feb 17, 2015 | 05:37 PM
Car: 91' camaro rs
Engine: Sbc 327
Old Feb 18, 2015 | 06:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Going that route to begin with, will no doubt save you some cash. Following are a couple of threads that should help, if and when, you swap:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Info about master, combination valve and parking brake:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 18, 2015 | 07:59 AM
Car: 91' camaro rs
Engine: Sbc 327
Thanks alot James!! That will get me to where I need to be!
Old Feb 18, 2015 | 08:43 PM
Car: 91' camaro rs
Engine: Sbc 327
If I decided to just go pbr when I do do it, how much $ are the delco-maraine backing plates worth? Thanks.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
