Wilwood FSL bracket for 13" rotors
Car: 1990 IROC
Axle/Gears: 10 Bolt 3.23
I have read through A LOT on here and have learned a ton. thank you all so much for sharing your knowledge. now i am upgrading brakes on two cars...gen 1 brembos front and rear on one and wilwood fsl front and rear on the other. i want the wilwoods on the other car because i want to keep the stock wheels. i found all the dimensions needed to be able to make them myself in a post by dean except the THICKNESS of the bracket. i'm using wilwood number 120-11135's and a c4hd rotor with a standard/non 1LE hub. help?
thanks
thanks
Car: 1990 IROC
Re: Wilwood FSL bracket for 13" rotors
anybody? this is the thread i got the other measurements from...
https://www.thirdgen.org/forums/brak...ds-my-way.html
Car: 87' IROC
I think you have your answer, but for future reference the bracket should be 3/8" thick when used with the C4HD 13x1.1" rotor.
dbrochard
09-25-2015 04:56 PM
///DAN///
09-25-2015 02:15 PM
